sdk3 Newbie
| Posted: Nov 15 2009 at 5:55pm | IP Logged
Is there any way to disable the keyless remote by pulling a fuse????that wont effect other systems....or does the remote reciever have it's own fuse? if so ,where would that be located?? also can the frequencies of the remotes and reciever be changed? it is a 04 crewcab thanks .................sdk3
| Posted: Nov 15 2009 at 7:54pm | IP Logged
WHY????? What is the main concern?
sdk3 Newbie
| Posted: Nov 15 2009 at 8:24pm | IP Logged
lost one of the romotes and suspect one of the neighbor kids has it......need to disconnect asap or re-program the remote and keyless remote reciever........I need to know where it is located?????....................thanks sdk3
| Posted: Nov 16 2009 at 9:23pm | IP Logged
If you reprogram the one you have, it will erase the memory of all the other ones. Get in the vehicle, lock the doors, insert key into ignition 6 times within 5 secs(or until the flashers flash), turn ignition to acc., push any button on remote, turn ign off, unlock and open door. If you purchase another remote and want to program it, start from the beginning, after the first remote, unlock and re-lock door, push any button on second remote, etc. etc.
sdk3 Newbie
| Posted: Nov 17 2009 at 10:55am | IP Logged
does this reprogram the reciever as well? or just the remotes? how would I know that it was reprogramed and the lost remote wouldn't work on my truck any more.?.........is there a fuse on the keyless reciever I can pull ?.simply to disconnect it............thanks
| Posted: Nov 17 2009 at 4:50pm | IP Logged
Read the first sentence of my last post.
sdk3 Newbie
| Posted: Nov 17 2009 at 8:35pm | IP Logged
thanks,,,,is there a way just to disconnect it by pulling a fuse.....I would rather disconnect it ,then see if we can't find the lost one.....then if we find it, we wont have to reprogram it....................
sdk3 Newbie
| Posted: Nov 21 2009 at 9:36pm | IP Logged
so how do I know what the frequency signal is....how do I know that after doing the re-program steps,that the guy down the roads or anyone elses remote wont open my truck ..............I really want to know were the transmitter is located under the dash ,,,I really just want to pull the fuse..........
| Posted: Nov 22 2009 at 12:30pm | IP Logged
You are being paranoid!!!! Once you reprogram any remotes, it erases all prior remotes. If you find the lost remote ,you can reprogram it with the other ones all at the same time.
sdk3 Newbie
| Posted: Nov 22 2009 at 5:37pm | IP Logged
frontierguy wrote:
| You are being paranoid!!!! Once you reprogram any remotes, it erases all prior remotes. If you find the lost remote ,you can reprogram it with the other ones all at the same time. |
thanks,,,,,if you had gone threw what we had this summer ,you would be paranoid also....I would really just like to disconnect it ,I can't imagine disconnecting would be that difficult...................
