| Posted: Mar 16 2010 at 9:28pm | IP Logged
Hello all,
I have a 2000 Nissan Frontier, 5speed V6 4x4. About a year ago I had a "full" tune up: new plugs, wires, cap. I had this done due to rough running, jumping motor while accelerating, and it worked. Now I'm experiencing a "bump"/"jump" while I'm cruising at highway speeds, with light to moderate acceleration on the motor (going up a hill.) The check engine light isn't coming on during this event. Could this be caused by "bad" gas, or is something wrong with the ignition system. Should I change any other components of the ignition system. The problem seems to be more active when the motor is warm. Currently the ABS light is on, but I assume that doesn't have anyting to do with what's going on now? (Maybe)......
The ABS light was on WAY before this issue.
...thanks for your time.
Brian
