Subject Topic: is 2500 rpms normal for 60 mph? Post ReplyPost New Topic
flipflop19d
U.S. - Kentucky
Posted: Apr 26 2010 at 3:41pm | IP Logged Quote flipflop19d
my '02 crew cab tachs 2500 rpms cruising between 60-65 mph. it feels like it's running alot harder than it should be for the speed. it's all stock and i recently changed spark plugs and wires. been this way for the month that i've had it. could it be because of the gears in the rear end? i am almost positive they're stock. how could i find out what gears it has?
thanks in advance for any help
"A young man who does not have what it takes to perform military service is
not likely to have what it takes to make a living. Today's military rejects
include tomorrow's hard-core unemployed." -JFK
Back to Top View flipflop19d's Profile Search for other posts by flipflop19d
Posted: Apr 26 2010 at 8:00pm | IP Logged Quote frontierguy
Automatic-standard trans-2wd -4wd??????????????????????
flipflop19d
U.S. - Kentucky
Posted: Apr 30 2010 at 9:08pm | IP Logged Quote flipflop19d
automatic, 4wd
Sorry about that
neezy13
U.S. - North Carolina
Posted: Apr 30 2010 at 9:25pm | IP Logged Quote neezy13
My '02 CC Auto 2WD runs at about 2700 between 65-70. I've had it since it was new and its always run that way as far as I can remember. 3.3L 170 hp is relatively small for a 4300 lb truck, so it works a little harder than the new 4.0L Frontys.
02 Nissan Frontier SE Crew cab V6 non-SC w/ long bed
Pioneer Premier HU w/Pioneer speakers in all doors and 2 Rockford Fosgate 8" subs
Greenville NC
Back to Top View neezy13's Profile Search for other posts by neezy13
VG33Frontier
Posted: May 14 2010 at 7:28am | IP Logged Quote VG33Frontier
Dude, I feel your pain. When my father first bought the truck, the moment he took it off the lot, he almost turned back. I'll never forget what he said that night:
"Oye, esto esta haciendo muchas revoluciones"
Or:
"Hey, This is revving very high..."
As someone said above..The motor is tiny, they had to make the motor cruise at it's fat power range...Even then, it's not that powerful...
Back to Top View VG33Frontier's Profile Search for other posts by VG33Frontier
mdemott
Posted: May 19 2010 at 8:01am | IP Logged Quote mdemott
I can run at 70mph turning 2k RPM's on my 07. I think Nissan used a lower final drive gear so the smaller engine could use more of it's pawer band. A taller electric O/D would help.
M DeMott
Stuart ,FL
07 LE Crew Cab
Back to Top View mdemott's Profile Search for other posts by mdemott
davidjbrady
Posted: May 19 2010 at 7:03pm | IP Logged Quote davidjbrady
Yes I have to agree, I had a 94 pathfinder V6 4X4 5 speed and at 62 MPH, it was 3000 RPM!!!! I even checked my odometer to ensure it was accurate, and it was.
Man was it a screamer, and also lacking on power.
Now my 08 frontier V6 4X4 with AT (5 speed) is 2000 RPM at 65 MPH. I get slightly better MPG (almost 20 mpg) and it has more power, is about 5 feet longer and also heavier. I have never put my frontier over 2700 RPM's, there is no need for it. I do some mountain passes and climbs and the VQ engine has so much low end torque.
08 Frontier CC, 4X4, LWB
Hu8nter
Posted: Nov 10 2010 at 8:17pm | IP Logged Quote Hu8nter
hey i have the same problem. i have an 04 frontier crew cab
5 speed manual 3.3L V6 and i top out 3000 rpm's at like 70.
if its true that the horsepower is my problem is there any
way to boost it without shelling out 4K-6K for a turbo?
Back to Top View Hu8nter's Profile Search for other posts by Hu8nter
