natesmall Newbie
Posted: May 24 2010 at 9:26am | IP Logged
Hello all,
This is my first post on here so hopefully it's worthy! haha.
I started having issues with my 98 Frontier, 4cyl 4x4, it would very
intermittently lost power. Be driving along then all of a sudden you
would have no power at all with the gas, or another time it sounded like a
bad spark plug and there was black smoke coming out the tail...(checked
plugs...they are fine). It stalled out a few times. No CEL was on. I
brought it into a shop and they managed to mimic the problem, then
they said they pulled codes and it was P0100...which is MAF. They called
me up and said I needed to replace it, a used piece was $475!!!!!! I asked
if they cleaned it and they said yup it needs to go though. I ordered the
part (comes in on wed. so I've got time), but I went to pick up my truck in
the meantime. I tested volts according to haynes manual on the MAF and
they were perfect. Both wires in the hole under the airfilter are intact and
looked clean. Does it need to
be replaced??? Or is that supposed cleaning they gave it good enough?
Thanks in advance!!!!
Nate Small
Jimmy54 Groupie
Posted: May 24 2010 at 2:03pm | IP Logged
By chance are you using a aftermarket air filter? Try and clean it and see if it
runs better!
natesmall Newbie
Posted: May 24 2010 at 3:03pm | IP Logged
just replaced the filter 2 weeks ago...and yes aftermarket...not OEM Oil
impregnated. Does it make a huge difference?
__________________ Nate Small
98 Nissan Frontier XE 4cyl 4x4
Jimmy54 Groupie
Posted: May 25 2010 at 6:09am | IP Logged
Yes makes a difference, I would change it to a OEM filter and clean the MAF
Posted: May 25 2010 at 8:54pm | IP Logged
DO what Jimmy54 says.
