Subject Topic: Help, truck "bucks" at 55-60 kmph Post ReplyPost New Topic
brandon
Posted: Jun 09 2010 at 8:21pm | IP Logged Quote brandon
hi Guys, this is my first time on the forum....i have a
2005 frontier that has given me really great service for
the past 5 yrs. I am only recently experiencing a problem
where the truck tends to buck on the 3rd & 4th gears when i
get up to about 55-60 kmph, other than that she runs just
fine...any suggestions as to what may be causing the
problem? (i changed the air & fuel filters but that didnt
help)....
Brandon
Sober Intoxication
Back to Top View brandon's Profile Search for other posts by brandon
Posted: Jun 09 2010 at 9:42pm | IP Logged Quote kcidmil
Brandon, need you to describe this "buck" in a little more detail.  It could be anything at this point.
~A tire thrown a weight, so it vibrates when you hit 55-60
~Transmission low on fluid causing the gears to slip back and forth.
ETC....
Does the engine feel like it surges, gaining power then losing?
Does it feel like the truck is shaking towards the front, toward the back?
The hmore info we have the better chances we can help you.
BTW, I moved you question into it's own thread to give it more visibility.
Jimmy54
Posted: Jun 10 2010 at 6:16am | IP Logged Quote Jimmy54
How many miles and is it a manual trans?
Posted: Jun 11 2010 at 7:30pm | IP Logged Quote frontierguy
Are you using a GENUINE NISSAN OIL IMPREGNATED AIR FILTER? Any check engine lite??? Fuel filter is incorporated into the fuel pump assy., did you change the whole assy?
Silvergeorge08
U.S. - Georgia
Posted: Jul 08 2010 at 12:29pm | IP Logged Quote Silvergeorge08
i think i have the same problem. my truck "bucks" when i let off the gas; rpm surges, but speed continues to decline without a foot on the accelrator. Then after i get back on the gas, then engine continues to surge (about 1k to 1.5k RPM), then eventually comes back down. It only does this about 5% of the time, but i wonder if its a sign of a larger problem
2008 LE, 60k miles, Automatic Transmission. Silver (if that matters)
i took mine in under warranty; couldnt get the truck to replicate it when the tech rode with me for about 20 minutes. Was scanned for codes, no codes came up. Was told to take it to a Transmission specialist and have them scan the AT for codes, but i havent done that yet.
On another forum i used to be on, my "help" stopped at "take it do a transmission shop"
Back to Top View Silvergeorge08's Profile Search for other posts by Silvergeorge08
