Subject Topic: 2001 XE - No cold air Post ReplyPost New Topic
DickCoz
U.S. - Colorado
Posted: Jul 17 2010 at 4:41pm | IP Logged Quote DickCoz
Inherited this car last winter, and haven't needed the A/C until recently here in Colorado (3 digits today).
Doesn't blow anything but warm/hot air. I've just begun to work on it. Found your forum on TCA and, although my problem sounds somewhat different than that forum, I was impressed at the amount of help provided there.
Does anything jump out at anyone about where I should start? I've checked fuses/relays, but that's it. Jumping 3&5 on A/C relay clicks clutch, but that's all I've done, so far.
HELP... please! Thanks
Not sure if this goes here... new member.
2001 Nissan Frontier XE King Cab V6-3.3L (VG33E)
2000 Ford F250 Super Duty V8-7.3L DSL Turbo
2002 Ford Escape 4WD V6-3.0L
1970 MGB RD
Back to Top View DickCoz's Profile Search for other posts by DickCoz
dmartin16
Posted: Jul 17 2010 at 11:38pm | IP Logged Quote dmartin16
I had the same problem last year..
Kragen / Checkers  / Auto Zone /Napa all have little AC kits, they run about $25, but they have a guage to check the pressure, a hose to connect to the AC system, and a can of the AC stuff. Works great, and is about 1/15th the cost of taking it to a shop. Be warned, make sure when you hook it all up, you do so per instructions, or bad things could happen. If you're uncomfortable with doing it at all, take it to a trusted mechanic. Also, you may need to put in a can of sealant, also found in the same vicinity as the AC recharge cans.
2003 Frontier XE (Base)
Back to Top View dmartin16's Profile Search for other posts by dmartin16
dmartin16
Posted: Jul 17 2010 at 11:40pm | IP Logged Quote dmartin16
Update, here is a link to Auto Zone's kit.
Link
DickCoz
U.S. - Colorado
Posted: Jul 18 2010 at 8:09am | IP Logged Quote DickCoz
Thanks. Will stop by Checkers this AM and give it a shot...
2001 Frontier XE King Cab V6-3.3L (VG33E)
1970 MGB RD
DickCoz
U.S. - Colorado
Posted: Jul 18 2010 at 4:13pm | IP Logged Quote DickCoz
$29 and 1/2 hour and it cools. I will keep an eye on it and report in a week or so.
This is a GREAT forum! THANKS!
1970 MGB RD
