Subject Topic: Chasing vibrations Post ReplyPost New Topic
Jasont
U.S. - Tennessee
Posted: Aug 07 2010 at 1:46pm | IP Logged Quote Jasont
First off, this site is great, used it to fix my a/c. I have a 2000 frontier 4x4 that starts to vibrate badly above about 40mph. Tightened my sway bar-no help. Checked my front u joints-no play it seems. tires are balanced. CV joints dont have much play. Is it cool to pull my front drive shaft to eliminate the poss of it being the problem rather than changing them for nothing?
Thanks
Jason
Back to Top View Jasont's Profile Search for other posts by Jasont
Posted: Aug 07 2010 at 7:51pm | IP Logged Quote frontierguy
If the rear driveshaft has ever been out to replace the carrier brg assy., it may have been assembled incorrectly, meaning the two u-joints are out of phase. Or possibly there is a bad u-joint.
Jasont
U.S. - Tennessee
Posted: Aug 08 2010 at 9:56am | IP Logged Quote Jasont
Rear driveshaft has never been out. I will check the rear u joints again in case I missed something. So, is it cool to drive it without the front driveshaft to eliminate it in the search?
Thanks
Jason
Posted: Aug 09 2010 at 8:56pm | IP Logged Quote frontierguy
Yes it is OK.
Boomer
Posted: Aug 12 2010 at 5:56am | IP Logged Quote Boomer
Consider that you may have an unbalanced drive shaft.  There are small weights on them that can fall off.  Look for a "clean" rectangular area that may indicate this.  It is not a big deal to have a shaft rebalanced.
2007 Nissan Frontier SE 4X4
