Subject Topic: Beach driving Post ReplyPost New Topic
SB LBI 2010
Posted: Sep 23 2010 at 3:03pm | IP Logged Quote SB LBI 2010
First I'm new--just purchased a 2010 SE 4x4 king in July with the sole purpose of surf fishing; therefor riding on the beach. Wednesday the Service Engine Soon light came on while on the beach (2,681 miles). Immediately took it to the dealer--they said it is caused by the wheels slipping while in 4wd low while in sand. WT%! Can this be right?
Back to Top View SB LBI 2010's Profile Search for other posts by SB LBI 2010
Posted: Sep 23 2010 at 7:19pm | IP Logged Quote frontierguy
Yes. Dumb question, but why would you expose a brand new vehicle to salt water? Up here in the northeast the road crews apply salt to the roads all winter which is brutal on our vehicles.
SB LBI 2010
Posted: Sep 24 2010 at 5:46am | IP Logged Quote SB LBI 2010
Oh, so buy a 4X4 keep it in the garage and only drive it on sunny days but keep to the street? Sorry I must be on the wrong forum.
thedave360
U.S. - Louisiana
Posted: Sep 24 2010 at 8:23pm | IP Logged Quote thedave360
nah, ur on a good forum. Frontierguy probably just hates to see brand new vehicles get exposed to corrosive stuff, like salt water. Lots of exposure could cause a bunch of rust in the long run. Take it to the carwash when you get back from the beach and it should keep you from rusting out too soon.
As far as the light goes, I would see if it will go off after driving a while on pavement (where the wheels aren't slipping). If it does, then I wouldn't worry about the light because you know its coming on because of the sand. If it stays on, maybe the dealer can do something like reprogram it or something. idk.
Shift_Your own gears
Baton Rouge, LA
'17 Frontier Pro4x/CC/MT
Boomer
Posted: Sep 25 2010 at 10:44am | IP Logged Quote Boomer
Yes.  +! on salt water rust.  Wash the truck underneath THOROUGHLY after being in salt water and also spray the entire upper body.  Salt water will find every little bit of exposed metal and you won't believe how fast it can corrode! All the years I fished in salt water with my outboard powered boat, I flushed the engine withing 1 hour of taking it out of the ocean to keep the internals corrosion-free.  And it worked.  If the rust gets going, the value of your truck will drop like a stone.
Good luck with the blues and sea trout!
2007 Nissan Frontier SE 4X4
Posted: Sep 26 2010 at 7:29pm | IP Logged Quote frontierguy
I didn't say that, I just can't justify taking a brand new or any vehicle for that matter and exposing it to such extreme conditions. I work very hard for a living and don't want to destroy what I have worked hard to achieve. Sorry.
jgreenjr
U.S. - Tennessee
Posted: Sep 27 2010 at 5:50am | IP Logged Quote jgreenjr
took autobody year and learned sait water will RUSTi seen this happen before ! i wouldn't take it to beach of saitwater ! stay on the street. you be safer than saitwater.
Proud owner of 03 Frontier
KA24DE
4X2
Jackie
A Proud owner of
2003 Nissan Frontier XE
4 cyl.
4x2
auto.
KA24DE
Stereo:Kenwood KDC BT648U
Ham radio since 2001 N4MJG
Tullahoma Tenn
Back to Top View jgreenjr's Profile Search for other posts by jgreenjr Visit jgreenjr's Homepage
jgreenjr
U.S. - Tennessee
Posted: Sep 27 2010 at 7:46pm | IP Logged Quote jgreenjr
or you can make sure you wash real good other wise rust problem !  I like to stay on street to be safe ! nothing wrong beging on beach just make sure you wash it real :)
Jackie
A Proud owner of
4 cyl.
4x2
auto.
KA24DE
Tullahoma Tenn
banditta66
Posted: Feb 09 2011 at 10:44am | IP Logged Quote banditta66
You shouldn't have to be in 4 low while driving on the beach. 4 high is fine. Drop your tire pressure down to 20 psi, and turn off the stabilization control.
I've never had vehicle rust from driving on the beach. F-150, Ranger, Tacoma, Xterra, and now Frontier - never a problem. Factory corrosion protection is pretty good these days, and it's not like you are sitting there submerged in salt water.
Back to Top View banditta66's Profile Search for other posts by banditta66
william
Posted: Feb 15 2011 at 6:25pm | IP Logged Quote william
So this started as a simple question and all you got is what seems like a lecture.
I agree with your question. You never said you were driving in salt water either.
I got a 2010 Equator with 32 miles on it on 31 Dec. I traded in my 04 2500 HD with 9" lift.
THE FIRST PLACE I WENT WAS TO THE BEACH!
I even went to some awesome wheelin spots AND GOT STUCK "SO WHAT"
I wasn't stomping the gas as the motor was not broken in. I have been to the beach ALMOST EVERY DAY since.
When I got back from the wheelin trip onto the asphalt my truck did the same thing and since I was in 4 LOW it took me a little while to figure out how to get back to 2wd. After driving in a straight line for like 10 miles the light went off.
Thanks!
William
william
Back to Top View william's Profile Search for other posts by william
Page of 2 Next >>
