Subject Topic: steering problems Post ReplyPost New Topic
indian
U.S. - Missouri
Posted: Mar 20 2011 at 7:09pm | IP Logged Quote indian
I have a new 2011 nissan frontier ccab 2 wd v6 auto trans.  The truck has play in the steering,  It seems to have more play at higher speeds 55 mph and faster.  Anyone have the same problem or any suggestions?
michael
Back to Top View indian's Profile Search for other posts by indian Visit indian's Homepage
Posted: Mar 20 2011 at 7:47pm | IP Logged Quote frontierguy
Check your tire pressures, might want to visit your dealer.
indian
U.S. - Missouri
Posted: Mar 21 2011 at 3:24pm | IP Logged Quote indian
Thanks for the reply, I checked all the tires they have 35 psi,  I also bled the front end 3 times.  I had it back to the dealer and the mechanic said that was typical for a frontier,  I am thinking it might have something electrical not working right?
michael
Posted: Mar 21 2011 at 7:30pm | IP Logged Quote frontierguy
There is nothing "electrical" to do with the steering. Have
you driven another to see if it is the same? Has the dealer
checked the front end alignment?
indian
U.S. - Missouri
Posted: Mar 22 2011 at 7:38pm | IP Logged Quote indian
Thanks for the reply,  I was thinking about having the front end aligned,  Someone told me they thought nissans had speed sensitve steering,  It just seems to have more control at slower speeds.   It is very frustrating to have a problem like this.  Thanks again for the reply.
michael
Posted: Mar 22 2011 at 8:13pm | IP Logged Quote frontierguy
I know on the '11 Quest they use electric/hydraulic power
steering which is "speed sensitive", not aware of it on the
Frontier.
indian
U.S. - Missouri
Posted: May 18 2011 at 5:45pm | IP Logged Quote indian
I had the front end aligned,  It was out a little but it did not help.  I am thinking It could have a faulty rack and pinion.  But it still seems to have more play in the wheel at higher speeds, 45 mph and above?
michael
