| Posted: Oct 10 2015 at 8:24am | IP Logged
mrydied wrote:
I'm new to this site and hope I am putting my issue in the correct place. I have a 2015 Frontier V6 with about 2000 miles. When I start it cold, the idle jumps anywhere between 2300 RPM and has went as high as 2800 RPM. I asked the mechanic at the dealership about it and he said it was suppose to cold start at these high RPM's. I'm a retired mechanical engineer and would never recommend running a cold engine at these high RPM's. On an older engine it could cause failure or at least, severe wear. Is there anyway to get the specifications or idle set points from Nissan. The procedure for setting them would also be great. mrm@chartertn.net |
Mike,
I have a '13 SVV6 and I also hate the High RPM Cold Engine Speed. I don't think that it is good for the engine either. I asked the Service Manager if the Cold Start RPM's could be lowered. He said yes, and they did an Idle Relearn,, but it didn't help my Truck.
Nissan Recommend's 5w30 and I think that is too thin, for Temperature's here in the Deep South, but I figure useing the Thinner Oil will help get the oil to the TopSide Faster on the High RPM Cold Start's, so that's what I am useing.
On my Previous Nissan Truck, '93 Hardbody 2.4, it didn't have a High Speed Cold Idle. Nissan also advised 5w30, but on that Truck I used 10w40 from the Getgo,, and it was still running great, 20 year's later, when I sold it after getting the '13 SVV6.
If I find a way to lower the High RPM Cold Engine Start's, I'll gladly get mine lowered. Until then,, I just grit my teeth, and hope the 5w30 is getting everything lubed.
My advice is to alway's use a Nissan Oil Filter as well, cause on the Cold Engine Start's, the Engine need's all the help that it can get to make sure everything is getting lubricated properly.
If you find a way to lower the RPM's, please let me know.
Good Luck,
