Frontier1 Groupie
Posted: Mar 30 2011 at 11:44am | IP Logged
07 frontier 6spd manual that has a small whining sound..this is the
first manual tran truck I've owned..is it normal?..seems to get louder
with higher rpms. I checked power steering fluid so I know its not
that.
__________________ 07 Nissan Frontier SE crew cab 4x4
Posted: Mar 30 2011 at 7:22pm | IP Logged
There is a TSB for the secondary timing chain tensioner
shoes wearing through which makes the plunger (metal)
contact the chain, thus the whine noise. Covered under your
5/60 power train warranty.
Frontier1 Groupie
Posted: Mar 31 2011 at 7:30am | IP Logged
Thanks! A buddy of mine also said it could be the air pump for the
emissions and its totally normal so ill check into both. I have an
appointment for routine service monday and ill mention both
possibilities to them
Boomer Senior Member
Posted: Mar 31 2011 at 6:14pm | IP Logged
Is wife or girl friend in the front seat with you??????
Posted: Apr 04 2011 at 6:33pm | IP Logged
TOO funny, Boomer. By the way, there is no air pump!!!!
