Subject Topic: how to change Map lights/personal lights Post ReplyPost New Topic
jetblue4400
Posted: Apr 29 2011 at 8:46am | IP Logged Quote jetblue4400
I have a 2010 crew cab and looking at the manual I'am not sure how to change out the Map lights /personal lights .My overhead lights are the push in buttons to engage the lights to come on.I don't know where to pry around the fixture to either remove the light bezels or the whole frame around the fixture? What I want to do is tap into the wiring and install may radar detector on the sun visor and use the 12 volts from the Map lights which would be only a  5 inch run of wire instead of going down to the fuse box.
Thanks
Back to Top View jetblue4400's Profile Search for other posts by jetblue4400
Posted: Apr 30 2011 at 7:46pm | IP Logged Quote frontierguy
The whole frame comes out, pry carefully on the back side.
