Subject Topic: 2011 Step Rail Install Post ReplyPost New Topic
msg148
Posted: May 02 2011 at 5:57pm | IP Logged Quote msg148
Hey guys, new to the Nissan forum and new to Nissan's in general. I just got
a 2011 Frontier and bought factory step rails from the parts at the Nissan
dealership. I got home to install them and the direction say I need to weld,
but the dealership says they have never done that. I have triple checked the
part number and it is the right one. I was wondering if anyone has put these
on and could offer advice or send me a video to help.
Thanks in advance
Back to Top View msg148's Profile Search for other posts by msg148
Posted: May 02 2011 at 7:47pm | IP Logged Quote frontierguy
No welding involved if they are indeed Genuine Nissan step
rails. Does it indicate Nissan on the box or
instructions????
FinalFrontier
Singapore
Posted: May 02 2011 at 8:36pm | IP Logged Quote FinalFrontier
I agree, even on some cardboards, there are seals or signings of "Genuine Nissan Parts or Accessories".
automotive seo = The best for car forums, car blogs or any other car sites
Back to Top View FinalFrontier's Profile Search for other posts by FinalFrontier
davidjbrady
Posted: May 03 2011 at 1:26pm | IP Logged Quote davidjbrady
Try this, go back to the dealer, and look at truck on the lot and see how they are installed.
I belive there are threaded holes on the frame
08 Frontier CC, 4X4, LWB
jgreenjr
U.S. - Tennessee
Posted: May 03 2011 at 5:02pm | IP Logged Quote jgreenjr
i have seen bolt on rather than welded i agree with David check other to see how they installed !
Jackie
A Proud owner of
2003 Nissan Frontier XE
4 cyl.
4x2
auto.
KA24DE
Stereo:Kenwood KDC BT648U
Ham radio since 2001 N4MJG
Tullahoma Tenn
Back to Top View jgreenjr's Profile Search for other posts by jgreenjr Visit jgreenjr's Homepage
Posted: May 03 2011 at 8:39pm | IP Logged Quote frontierguy
There are studs on the truck that the step rail brackets
are attached to, then the rails are bolted to the brackets.
jgreenjr
U.S. - Tennessee
Posted: May 03 2011 at 8:52pm | IP Logged Quote jgreenjr
It better bolt on than the weld i would rather have bolt then welded job ! make it easy for us !
Jackie
A Proud owner of
4 cyl.
4x2
auto.
KA24DE
Tullahoma Tenn
Frontier1
Posted: May 04 2011 at 7:47am | IP Logged Quote Frontier1
I put step rails on an 08 xterra that I bought from parts
counter at the dealer. Took em home and bolted them on
and was done in 15 mins. Just bolt the 90° brackets
underneath to the studs on the frame and put the rails on
them and tighten the bolts underneath to secure them. Very
easy add on that gives function and a good look to the
vehicle.
07 Nissan Frontier SE crew cab 4x4
Back to Top View Frontier1's Profile Search for other posts by Frontier1
psmith9523
U.S. - Georgia
Posted: Jun 19 2011 at 6:38pm | IP Logged Quote psmith9523
Exactly what Frontier1 stated:  I just installed my step-rails two days ago.  I purchased a 2011 CrewCab SV,,,I worked the step-rails in with the deal.  They had to pull them from the Parts/Accessory area.  It was getting late and they were going to install them the next day.  I told them to strap them in the bed and I will install them when I arrived home.
1. Mount the "left side" (Drivers side) brackets to matching frame studs, then attach the actual step rail to the bracket.
2. Repeat "right side" (Pass side).
The kit should contain both step-rails, the nuts to mount brackets and the bolts to attach step-rails to brackets.  Each bracket is labeled "left side" and "right side".
Back to Top View psmith9523's Profile Search for other posts by psmith9523
Annada
Posted: Jun 20 2011 at 5:05am | IP Logged Quote Annada
The innovative design of MBT Shoes clearance beads becomes more and more attractive.
Back to Top View Annada's Profile Search for other posts by Annada Visit Annada's Homepage
