Subject Topic: no power??? Post ReplyPost New Topic
boyd 8080
Posted: May 11 2011 at 2:20pm | IP Logged Quote boyd 8080
i am new to the site so hope this is in the right spot. the vehicle is a 2000 nissan frontier xe 4x4 4 door with a 3.3 motor well heres the story the vehicle died on the way home, pulled the codes and it had a camshaft code and a knock sensor code. i replaced the distributor for the cam sensor, and it would still not stat i cleared the code and just the knock sensor code came up, i replaced the knock sensor, went to start and it still would not start so i stated to think that it jumped time so i pulled the front cover off and sure enough the driver side cam was one tooth off, so i bought a new timing belt put it on and it fired right up. but still had a check engine light, pulled the code and the iac p0505 code came up and it had a rough idle, i pulled the iac valve out cleaned it and now idles smooth and has no codes. i went to test drive and it had no power would just fall on its face and not even move, i am starting to think that is has plugged cats. all wires and vacum lines have been checked/ looked at and are in there correct spots. i am tired of spending the money and chasing parts. is there any one out there that can help me on this one??? i would love the help if any one has any ideas on what else this might be. thanks love the site
Back to Top View boyd 8080's Profile Search for other posts by boyd 8080
Posted: May 11 2011 at 7:56pm | IP Logged Quote frontierguy
MAFS???????
boyd 8080
Posted: May 12 2011 at 12:19pm | IP Logged Quote boyd 8080
on my monitor i was getting a correct read out on the mass air flow sensor, and when i un plug it while its running the vehicle dies instintly like it should, i am leaning toward the cats i pulled the upstream o2 sensors out and started it up and it seemed to have lots of power, but what i dont get is thats  not what killed the vehicle in the first place so why all of a sudden would the cats seem to be plugged? just seem like i and chasing and chasing and its always something else. i hve working for nissan for 4 years as tech and this is my own personal vehicle and i cant seem to chase the problem down.
Posted: May 12 2011 at 7:59pm | IP Logged Quote frontierguy
Did you monitor the MAFS in data monitor "SPEC" to see if
it is w/in parameters?
