| Posted: Jun 25 2011 at 4:35pm | IP Logged
Welcome to the group!
Vapor lock is a condition where a liquid becomes a gas in a pump or its feed line. Some times it is caused by a drop in pressure and/or a rise in temperature. In an engines cooling system or a boat propeller there is a condition called cavitation. IMHO… (I didn’t take time to look it up) In the engine cooling system cavitation is some what similar the boat propeller. Bubbles form on the rotating blades of the pump and reduce efficacy of the pump. Sooner or later the blades of the pump will erode and further reduce the pumping action. And remember old coolant is not good for your engine.
Have a good one.. Don S..
