Emmette Newbie
| Posted: Aug 04 2011 at 4:16pm | IP Logged
Have a '98 Frontier 2.4L. Have replaced MAP sensor, Idle
speed control and still have a problem with engine dying
after warm up. DTC shows P0450 which is not always shown.
Any suggestions?
__________________ Emmette E
| Posted: Aug 04 2011 at 8:20pm | IP Logged
How about the MAFS, has that been replaced? Are you using a
Genuine Nissan oil impregnated air filter? Many
possibilities for the P0450 code.
Emmette Newbie
| Posted: Aug 04 2011 at 8:43pm | IP Logged
Haven't changed the MAFS sensor yet due to the cost :)
However, been looking at that very real possibility. Was
hoping someone had a cheaper cure..... Have NOT gone to the
genuine Nissan oil impregnated air filter. Will probably
try that first.
| Posted: Aug 05 2011 at 7:40pm | IP Logged
You could try and clean the MAFS with an approved cleaner.
Emmette Newbie
| Posted: Aug 05 2011 at 7:48pm | IP Logged
Will try that Sunday as soon as the auto parts store opens.
Found a new MAF sensor on Ebay for $53 ($56?) and might go
ahead and order it just in case. Most I have found were
well over $200 which is quite steep for my finances...
