Subject Topic: tranny and diff oil Post ReplyPost New Topic
cwrepo
Posted: Oct 07 2011 at 5:17pm | IP Logged Quote cwrepo
Hello All,
Im new to owning a Frontier, my other car I owned was a jeep wrangler.  I want to change the fluids in my truck.  I purchased it used and not sure what the previous own did with the truck.  I have read so much online about royal purple, mobil 1 and amsoil.   Amsoil is a pain because I have to order it and wait for it to come in.  I would rather be able to walk into a store and walk out with what I need.  So which is better?  Royal Purple for everything or Mobil 1?
I have read that you just put ATF oil in the tranny if that is the case can I just put Royal Purple MAX ATF in both or will it mess something up?  Also in the differentials cn I just put royal purple max gear in both or should I use mobil 1 in those?
Thanks for the input
Chris
Oh and the truck has no warranty so no need to worry about voiding the warranty
2006 Frontier Crew Cab 4x4 Nismo
Back to Top View cwrepo's Profile Search for other posts by cwrepo
cwrepo
Posted: Oct 07 2011 at 5:18pm | IP Logged Quote cwrepo
Correction I have read that you just put ATF in the tranny and the transfer case, so do I just put max ATF in both or MAX ATF in one and something in the other
Posted: Oct 07 2011 at 6:58pm | IP Logged Quote frontierguy
Nissan has many different ATF designations, Matic D goes in
the transfer, Matic J which changed to Matic S, goes in the
transmission(assuming it is an automatic).
cwrepo
Posted: Oct 07 2011 at 9:52pm | IP Logged Quote cwrepo
Yeah i wont be using nissan fluid. Looking to see which is better
mobil1 or the royal purple and how much goes ot each thanks
Posted: Oct 11 2011 at 8:47pm | IP Logged Quote frontierguy
GOOD LUCK!!!!!!!
