HangDiver Newbie
| Posted: Oct 13 2011 at 6:03pm | IP Logged
The truck is a 2007 Crew LB with a six speed manual. When the
engine/trans is cold (first start of the day) it's difficult to shift 1st,
2nd, and 3rd. 4th through 6th work fine. After it warms up it's much
better. Syncros?
It has 60K miles.
TIA,
Rich
| Posted: Oct 14 2011 at 6:12pm | IP Logged
Welcome to the "lousiest trans ever built club", mine has
done it since day one. Adjust the free-play to the minimum
for the clutch pedal, be sure you don't have "thick" floor
mats, and be sure to push clutch to the floor when
shifting. After driving a "96 Tacoma for 7 yrs and 156K, it
was very difficult adjusting to the lousy Frontier trans.
HangDiver Newbie
| Posted: Oct 14 2011 at 10:24pm | IP Logged
Had a 2000 Xterra that had to push the clutch to the firewall to shift.
Friction point on this clutch is much better. Still, going all the way to
the floor still makes for difficult shifting while cold.
Drive train warranty ran out 300 miles ago.
Need help...
| Posted: Oct 20 2011 at 7:40pm | IP Logged
Did you have the concern prior to 60K and any record of
this at the dealership? Many times they will do a
"goodwill" claim to correct a concern that is just out of
warranty. I know a lot of guys like to do there own work,
but it does pay to visit your dealer to show some
patronage.
Frontier1 Groupie
| Posted: Oct 21 2011 at 9:20am | IP Logged
I totally agree! On cold starts 1st-3rd seem a little "clunky" for lack of
a better term ,for the first couple shifts. After it gets warmed up
seems much better though
__________________ 07 Nissan Frontier SE crew cab 4x4
NPHLYT Newbie
| Posted: Oct 21 2011 at 2:27pm | IP Logged
Maybe it is time to change the tranny fluid. I did my other car at ~90 and it felt like a new transmission. Also, flush the clutch master & slave cylinders with new fluid (do the brakes while you are at it).
__________________ NPHLYT
2011 Pro 4X - Manual, baby!
| Posted: Oct 21 2011 at 6:33pm | IP Logged
NPHLYT,
I replaced all my fluids at 3,000 miles, using Nissan full
Synthetic in the trans, no change in operation.
HangDiver Newbie
| Posted: Oct 21 2011 at 9:17pm | IP Logged
any record of
patronage. |
Thanks for the reply!! The problem just started so there's no history
or record of it at the dealer. I'll probably end up taking it there and
see if they'll warranty it being that it has 60,800 miles.
Unfortunately the closest dealer is 2.5 hours away.
Other than this, I really like the truck.
HangDiver Newbie
| Posted: Oct 21 2011 at 9:20pm | IP Logged
Changed the trans fluid with syn 4,000 miles ago. Didn't do the clutch
and slave. Good idea! Thanks.
eitydeuce Newbie
Online Status: Offline Posts: 24
| Posted: Mar 14 2012 at 8:52pm | IP Logged
Carefull with the synthetics guys! I'm all for the bigger and better but with enough miles things start to leak with a change over to synthetic. I recently switched back to conventional and have had no leaks.
