| Posted: Oct 25 2011 at 10:21pm | IP Logged
Welcome to the group!
What does the heat gauge say? Have you tried a new cap? While in Park have someone rev up the engine in short bursts and look to see if the lower hose colapses. Was the thermistat replaced? Was the cooling system air bled when it was refilled? Even in a warm climate youshold be using a 50 - 50 mix of antifreeze and distilled water?
It some times helps to know what Year and model Frontier you are having trouble with and the running gear as well as the the mileage!
Good Luck.. Don S..
