stonewater Newbie
Posted: Nov 27 2011 at 6:17pm | IP Logged
hello,
I have a Frontier 2002, currently my vehicle cuts out on me. while im driving or the vehicle is sitting while sitting in one place. the vehicle will cut out. This happens more frequently when the weather is warmer say around 65 and above. Once it stops, I have to wait for about an hour or so for the vehicle to start up again.
I have so far replaced the fuel pump, fuel filter, the relay.
When its connected to a diagnostic computer the code for the nock chip appears only when the check engine light is on.
Does anyone have any ideas as to what may be the problem with my vehicle, oh a side note Nissan has even looked at my vehicle they had it for a week and could not figure it out.
I would appreciate any help i could get.
Posted: Nov 27 2011 at 6:59pm | IP Logged
How many miles? V-6 ???? Possible distributor is failing.
stonewater Newbie
Posted: Nov 27 2011 at 7:40pm | IP Logged
miles: 170,000 but Nissan stated they thought it was the distributor but when they inserted the new distributor the vehicle proceeded kept shutting down. so Nissan put back the old distributor then they said the checked the relay but that was not it.
Posted: Nov 27 2011 at 10:02pm | IP Logged
It would appear something is getting hot causing the shut down. It sure sounds like a vapor-lock. Though probably not a V-lock it wouldn't hurt to check the fuel pressure while not running. Check the fuel lines. Move or insulate were they come close the hot spots.
Check the heat sending unit. Check coolant levels and Fan clutch. It's possible an electrical connection is parting when the wire looms get hot. Clean all ground connections.
Good luck!! Don S..
Posted: Nov 30 2011 at 7:54pm | IP Logged
Has the fuel sending unit recall been done?
stonewater Newbie
Posted: Nov 30 2011 at 9:55pm | IP Logged
a fuel sending recall was issued for a 2002 Nissan frontier 6 cyl 4x4?
stonewater Newbie
when did this happen?
Posted: Dec 01 2011 at 8:25pm | IP Logged
NTB04-062C I.D.#R0401 or R0402 depending on whether or
not it is in a salt state. It came out sometime in '04
stonewater Newbie
Posted: Dec 04 2011 at 1:33pm | IP Logged
i purchased it in California
Posted: Dec 04 2011 at 7:45pm | IP Logged
Check with the dealer, have them check service comm for any
recalls.
