Subject Topic: bad fuel pressure regulator?? Post ReplyPost New Topic
NorthrnManitoba
Canada
Posted: Dec 19 2011 at 10:09am | IP Logged Quote NorthrnManitoba
i own a 2007 frontier nismo 4x4 auto 4.0 litre v6
occasionally after truck has sat say overnight and the temperature drops below maybe -25 degrees celcius
the truck will have a fast strong crank, but will not catch and fire up!  the other day i tried boosting it even though i am pretty sure my battery is ok!~  at first no luck with boost but then with a boost still hooked up i hoped into my truck and wiggled the gear shifter making sure that park switch was being met and i cycled my key off and on approx 2-4 times before going to start truck . it started right up for me let ir run for say 5 minutes then shut it off and tried to start it agian it started up fine after.   it did seem to rev a little bit higher then normal after i got it started the first time for what seemed like longer than usual. i am not 100% sure but i think my gas milage is a little bit worse than normal now too>
does thgis sound like a bad fuel pressure regulator??
i have already had the fuel pump replaced and i have a new ipdm e/r
someone plz help me!
2007 nissan frontier NISMO 4x4
4.0 litre, V-6, auto
Back to Top View NorthrnManitoba's Profile Search for other posts by NorthrnManitoba
Posted: Dec 19 2011 at 7:20pm | IP Logged Quote frontierguy
Very possible. Not sure if it is available as a serviceable
part, Versa and Sentra are available. Was the pump replaced
or just the fuel level sensor? At least you are getting a
grip on why it is not starting.
NorthrnManitoba
Canada
Posted: Jan 03 2012 at 8:12am | IP Logged Quote NorthrnManitoba
false alarm   tried cycling key again didnt work
hooked up a boost.. fired rite up
man this sucks
had in in at dealership over the hoidays again cant recreat problem cant find anything wrong!
i think my ecm module is the culprit.
 when its really cold out its almost like it gets a slightly higher resistance   which needs an extra boost of voltage to work properly.
nothing seems to be drawing my battery down after a long cold soak it cranks strong. just maybe not quite enough voltage to communicate properly with ecm???
help me someone please
Posted: Jan 03 2012 at 9:15am | IP Logged Quote lakota
When and if all else fails!
Back in the mid 1950's A friend had an Oldsmobile that had starting problems. In those days cars had 6 volt battery systems. The battery was replaced with an 8 volt battery and no other changes. This fixed the starting problem. All the lights burned brighter which means they will burn out sooner but it wasn't... in his case... a problem. Maby a 16 volt battery could be installed with an isolaton switch and only used when needed. Most electrical devices are designed to handle up to 50% more voltage than in normal use.
I'm not recomending this action... I'm just sayin'.... Good Luck.. Don S..
http://www.batterycentralmall.com/Batteries/TurboStart/Turbo Start_Racing.html
