| Posted: Dec 21 2011 at 7:04pm | IP Logged
Jack the truck up, lock the hubs, verify that the axle
spins when you spin the wheels by hand, that will verify
the hubs are engaged. With the truck still jacked up, see
if the front drive shaft spins in 4WD, you should be very careful and have an assistant.
