| Posted: Jan 31 2012 at 3:43am | IP Logged
Check engine light not on ...originally thought it was a distributor issue until I read this forum, however I am from Florida and it has been pretty dry here lately and right now I am having the issue. I did end up with it happing again yesterday and 2 things are seemly standing out. The fuel gauge has be below half and once it is if I let it idle for 10 minutes that will be enough to induce it, as soon as I put gas in it the trouble stopped. I can't locate my record for fuel filter so I will change it next and re-post......Thank You
