nfields Newbie
| Posted: Jun 12 2012 at 10:00am | IP Logged
My 98 Frontier was overheating so, I've changed the radiator, thermostat,
water pump, cluster, and fan clutch. Still overheating, I need some help,
any suggestion?
davidjbrady Senior Member
Online Status: Offline Posts: 359
| Posted: Jun 12 2012 at 6:16pm | IP Logged
Looks like all that is left is heater core? not sure if the heater core only has water pass through when is is turned on? See if it overheats with heater turned on...
By cluster, are you referring to the temperature sending unit? That could be bad...
Also what engine do you have?
David
| Posted: Jun 12 2012 at 8:42pm | IP Logged
head gasket???? What is the coolant set for? If it is
straight, it will cause over heating. 50/50 is suggested.
nfields Newbie
| Posted: Jun 12 2012 at 9:01pm | IP Logged
It is a four cylinder engine... Cluster in my Dash.... I will check my electrical
side of the house and heater core?? Fluid is flowing from the reservoir and I
will check the heater being on as well...... Thanks
I do use 50/50 coolant..... Please don't say head gasket.......
nfields Newbie
| Posted: Jun 13 2012 at 8:23pm | IP Logged
Thanks for the advice, it was electrical but, I have a lot of new parts and
practice??
