Posted: Sep 05 2012 at 8:43pm | IP Logged
DTC P0510: CLOSED THROTTLE POSITION (TP) SWITCH DTC P0120: THROTTLE POSITION (TP) SENSOR When installing the TPS, it has to be adjusted correctly failing which it would cause the code to show. 1. Check Base Idle Speed Check
idle speed. Base idle speed should be 650-750 RPM with transmission in
Park or Neutral. If idle speed is as specified, go to next step. If idle
speed is not as specified, adjust by turning idle speed adjusting
screw. See Fig. 16 . Go to next step.  2. Check Closed TP Switch Idle Position Turn
ignition off. Reconnect all harness connectors. Start engine and warm
to normal operating temperature. Turn ignition off. Disconnect TP switch
harness connector. See Fig. 17 . Insert a .012" (.30 mm) feeler gauge
between throttle adjusting screw and stopper. See Fig. 18 .   3.
Check continuity between TP switch terminals No. 4 and 5. See Fig. 17 .
Continuity should exist. Remove .012" (.30 mm) feeler gauge, and insert
.016" (.40 mm) feeler gauge. Continuity should not exist. If continuity
is as specified, go to step 6. If continuity is not as specified, go to
next step. 4. TP Sensor Idle Position Adjustment Ensure
engine is at normal operating temperature. Loosen TP sensor bolts.
Remove .016" (.40 mm) feeler gauge, and insert .014" (.35 mm) feeler
gauge. Open and close throttle. Continuity should not exist while
closing throttle. If continuity exists, turn TP sensor body clockwise
until continuity does not exist. 5. Remove .014" (.35 mm) feeler
gauge, and insert .012" (.30 mm) feeler gauge. Slowly rotate TP sensor
body counterclockwise until continuity exists, then tighten TP sensor
bolts. Ensure continuity exists when throttle is closed and does not
exist when throttle is open. Repeat 2 or 3 times. Remove .012" (.30 mm)
feeler gauge, and insert .016" (.40 mm) feeler gauge. Ensure continuity
does not exist when throttle is closed. Repeat 2 or 3 times. Go to next
step. 6. Reset TP Sensor Idle Position Memory Remove
feeler gauge. Reconnect all harness connectors. Start engine and warm
to normal operating temperature. Turn ignition off. Turn ignition on,
wait at least 5 seconds, then turn ignition off and wait at least 5
seconds. Repeat 20 times. Go to next step. 7. Check Target Idle Speed Check
idle speed. Target idle speed should be 700-800 RPM with transmission
in Park or Neutral. If idle speed is as specified, go to next step. If
idle speed is not as specified, adjust by turning idle speed adjusting
screw. See Fig. 16 . Go to next step. 8. Clear DTC Memory DTCs
may be stored in ECM and/or Transmission Control Module (TCM) from
performing basic inspection. Clear DTCs from ECM and TCM.
__________________ 2001 Nissan Frontier Crew Cab 3.3 SE!
1974 Kawasaki F9 350 Big Horn,
1981 Kawasaki KZ1000J1,
1984 Kawasaki KZ700A1,
1997 Honda XR400R,
2001 Honda XR200R,
