charger490 Newbie
Online Status: Offline Posts: 28
| Posted: Nov 06 2012 at 12:40pm | IP Logged
just got the letter .now i will get some of my money back that i had to pay for my radiator and transmission replacement 6400.00. they are going to put up a web site in the next 2 weeks at www.nissanassist.com frontier guy is there a way to tell if they instaled a new tranismission and radiator in my truck or did they flush it and fix the radiator
__________________ 66 dodge charger
68 dodge charger
58 plymouth
97 honda crx
2001 honda crv
2006 frontier
| Posted: Nov 06 2012 at 6:58pm | IP Logged
No fix to the rad. Does it look clean and new? Should be
able to see bolts and nuts that have had a wrench or socket
on them in order to remove trans. Compare the transmission
housing and transfer housing, they should be different in
cleanliness.
frontiertech90 Newbie
| Posted: Nov 25 2012 at 10:30am | IP Logged
You more than likely got a reman transmission from Nissan. Nissan
rebuilt a unit that was sent back to them which is as good a new. You
cant fix a radiator. My suggestion, which i have done to several
Frontiers, Xterras, and Pathfinders, is install an auxiliary trans cooler.
Nissan does not offer one but the aftermarket world does. Eliminate this
problem once and for all. Worth the investment.
charger490 Newbie
| Posted: Nov 25 2012 at 11:17am | IP Logged
thank you for the info .i have already changed the cooler to the outside.they said the new trany is gurenteed for 8 more years. thanks agian
68 dodge charger
58 plymouth
97 honda crx
2001 honda crv
2006 frontier
sundug Newbie
| Posted: Jan 25 2016 at 2:39pm | IP Logged
Is the Hayden 678 aftermarket trans cooler sufficient by
itself?
__________________ "One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
| Posted: Jan 25 2016 at 3:08pm | IP Logged
It would depend on the duty cycle and what model...
Whatcha got.. Don S..
sundug Newbie
| Posted: Jan 25 2016 at 5:18pm | IP Logged
Whatcha got.. Don S.. |
2010 2.5 4 cyl 5 spd auto
| Posted: Jan 25 2016 at 8:34pm | IP Logged
Tranny heat is created by pressure from effort x time.
Pulling trailers and climbing long grades or strong headwinds = extra heat.
If you operate up north you need the radiator in the system to warm the tranny in the winter.
You'll probably be OK with just a good Aux. cooler.
Good luck.. Don S..
