motorhead1352 Newbie
| Posted: Dec 28 2014 at 1:56pm | IP Logged
Headlights come on but emergency flashers,
radio and fan blower do not! Always started
before now bit only clicks now. It has a
brand new battery.
__________________ Motorhead
| Posted: Dec 28 2014 at 2:36pm | IP Logged
Sounds like a ground wire problem. It could be the connection at the starter or elsewhere.
Might state what the truck is model wise...
Good luck.. Don S..
| Posted: Dec 28 2014 at 2:45pm | IP Logged
Frontier XE
Thank you.
| Posted: Dec 28 2014 at 6:32pm | IP Logged
Have someone hold the ignition key in the "start" position
while you tap on the starter with a long rod, if it starts,
it needs a starter.
