Subject Topic: 2012 Frontier rear end/differential Post ReplyPost New Topic
frontierx376
Posted: Aug 26 2015 at 7:53am | IP Logged Quote frontierx376
Last week I had noise I thought was coming from the front tires. took it to the dealer, and they tell me I need a whole new rear axle assembly put in due to the gears being chewed up in the differential. This truck, a frontier king cab, SV 4x4, with a manual transmission, 4.0 motor has very low miles on it, only twenty thousand. Has anybody else had this issue or know of an ongoing problem with these rear ends, thanks for any feedback.
Back to Top View frontierx376's Profile Search for other posts by frontierx376
alex973
U.S. - New Jersey
Posted: Sep 09 2015 at 6:52pm | IP Logged Quote alex973
My NISMO is 07 they told me the same BS since 34k miles, the same dif now has 190,000 today yes it makes noise
above 75-80 otherwise, I tow my car no problems weight is around 5000lbs use better rear dif grease
alex06NISMO
Back to Top View alex973's Profile Search for other posts by alex973
Rubble
Posted: Sep 10 2015 at 6:44pm | IP Logged Quote Rubble
Better Dif grease?  Would you explain please?
Barney
