Lostyank Newbie
Posted: Mar 28 2016 at 9:27am | IP Logged
I have a 2013 Frontier 2.5 SV. I am having problems with water coming out of the heater ducts. A lot of water. My coolant level is fine, so is there a condensation issue? I have changed my cabin filters per my discussion with the dealer. Any ideas? Thanks.
__________________ 2013 Frontier SV
Posted: Mar 28 2016 at 5:44pm | IP Logged
What part of the country are you located? Is the A/C
control set on "FRESH or RECIRC"? Check your A/C evap
drain for being plugged.
Lostyank Newbie
Posted: Mar 29 2016 at 4:17am | IP Logged
Thanks for the reply. I live in Georgia. I have been running it on fresh air. I will check out the A/C evap drain. I will run the a/c and see if I do get any condensation drain on the ground while it is running to be sure. Thanks again!
