Yellowhammer Newbie
| Posted: Jan 03 2017 at 4:13pm | IP Logged
Got a 2007 Frontier that went
dead when I slowed to go over a speed bump. It cranked back up only
with vigorous pumping of the gas pedal while grinding on the starter.
Since then, it's difficult to start but once started, it seems to run
fine. So, it seems for some reason, the engine is not getting enough gas
to start. Any ideas? Thanks.
| Posted: Jan 03 2017 at 8:24pm | IP Logged
You might try a new Nissan air filter for the engine.
Good luck.. Don S..
| Posted: Jan 12 2017 at 7:25pm | IP Logged
2nd on the Nissan air filter, clean the MAFS, clean and
tighten all engine grounds, clear the self learn(dealer)
and perform IAVL(dealer). Was that ever recalled for the
ECU relay????
