tom0710 Newbie
Posted: Sep 23 2019 at 6:56am | IP Logged
I am wondering if the Frontier Desert Runner uses 4x4
front wheel bearings since it has a 4x4 suspension.
I bought 2WD bearings and they will not slip onto the
spindle. The diameter is too small.
1A Auto tells me it takes 2WD bearings, but they don't
fit!
Posted: Sep 29 2019 at 4:49pm | IP Logged
Are the bearings bad or do they need clean and repack?
If 2 wd are too small, then 4wd bearings should work.
tom0710 Newbie
Posted: Sep 29 2019 at 6:33pm | IP Logged
The bearings look good. I was going to replace them
since the alignment shop said they should be replaced.
But I don't see any bad signs of wear and the wheels are
tight.
153,000 miles on them
