Raeban61 Newbie
| Posted: Jul 13 2021 at 9:13am | IP Logged
Good morning I have been having a hesitation problem
when accelerating with my Frontier. It happens
occasionally under hard acceleration, or when the truck
is loaded. I put fuel injector cleaner through a couple
of tanks, cleaned the MAF sensor and cleaned the
throttle body. This seemed to clear it up for the most
part, but it happened again when passing on the highway
and when climbing an overpass. I have had the truck for
about 2 years, and don't know when the plugs were
changed last. Could it be the throttle position sensor?
Any thoughts would be greatly appreciated.
Rubble Moderator Group
Online Status: Offline Posts: 392
| Posted: Jul 13 2021 at 9:55pm | IP Logged
Raeban,
The Preventative Maintenance should have been started as
soon as you took ownership. Waiting 2 year's to know about
the Plug's is Maintenance Neglect IMO.
If it were me, I would take it to Nissan and let them check
it out. They'll give you an estimate and then you can let
them do it, do it yourself, or take it somewhere else to
have it done.
Once the Truck is Straigtened out, then pick up the
preventative maintenance as outlined in the Maintenance or
Owner's manual. If you need the Service Manual get the
Geniune Nissan Service manual. There's a place that you
can purchase the CD for less than 20 $'s.
https://www.nissanfrontier.org/forum_posts.asp?
TID=6546&PN=1
Good Luck
