984by4 Newbie
| Posted: Oct 28 2006 at 7:49pm | IP Logged
I had the same problem and after a couple of years I decided to install a new clutch, throwout bearing and pilot bearing. I found the noise... it was caused by the pilot bushing being installed too far into the crank so only part of the transmission shaft was in the bushing. I don't know if it would have caused any problems, but I just got tired of the noise. BTW, if you remove the transmission it's a very good idea to replace the clutch, pressure plate, throwout bearing and pilot bushing... cost me only about $160 in parts total, but it's a lot of work.
