| Posted: Jul 11 2011 at 4:16pm | IP Logged
Discount tires has a size conversion guide that can tell you the diameter size increace. Cranking the 'T-bars' one inch or less and maby mild trimming should give enough clearance. If the T-bars are cranked up have the front end alighnment checked.
Good luck.. Don S..
