| Posted: Feb 18 2007 at 8:51pm | IP Logged
Hmm... that would be a hard one for a few reasons.
find a Nissan that used the same rear design and had disc?
Almost impossible because Nissan's 350z probably doesn't even use the same design, but it might be a place to start looking. The hard part is most of Nissan's stock is in FWD or AWD, and even then they're using independent suspesion.
You're best plan of attack is getting a generic set or rotors from a vehicle that used the same pattern. Possibly the 300xz? (don't qoute me on that) Then grab the calipers as well (because you'll need them for the parking brake) Then fab up your own brackets.
Or you can get a 2nd set of rotors that are the same size as the front, as well as another set of calipers. Fab up the brackets.
Remember also that the master cylinder resivoir on a 4 disc is smaller than that of the disc/drum setup. And you might run into a nightmare if the Rear Wheel ABS that came on almost all of Nissan's trucks.
