| Posted: Jul 26 2009 at 12:22pm | IP Logged
lol.. the tire sizes you mentioned are fairly close to being the same size
265/75/16 will give you a wider contact patch but might be slightly shorter than the 255/85/16
the 255/85/16 (depending upon tread pattern design) would be better for snow and ice. that 85 isn't going to give you a much "bigger" look over the other.
If I remember my sizes correctly, you're looking for around a 33" tire?
