| Posted: May 27 2010 at 3:14pm | IP Logged
jennaK:
Welcome to the group!
There are eight or more unrelated suspension and running gear systems in the 1998 to 2010 Frontiers.
Have a good one while you can afford it! Don S..
Here is a paste-up list of some the things needed for comparing wheels.
Diameter width lug pattern back space centering hole size - lug/hub centric? (centering) stud size - lug style lug size -
Titan Bolt pattern is 6-5.5" also listed as 6-139.7mm sometimes.
Weld's wheels application catalog references Titan hubs as 3.072 HUB I.D
The 1999 Frontier Se cast aluminum 4x4 wheels are hub-centric, 6 lugs on 5.5 dia., 15dia. X 7 wide, 5.250 Back Spacing, centering hole is 3.925 inches in diameter.
TIRES
http://www.discounttire.com/dtcs/infoTireMath.dos
. Modifying a vehicle with lifts and larger or wider tires is detrimental to fuel mileage and brake life.
