Subject Topic: Fog Lamp Install?? need help Post ReplyPost New Topic
Drews04fronty
Posted: Jul 09 2010 at 9:03am | IP Logged Quote Drews04fronty
Iv been searching for a while now and still cannot find anything about how to install the OEM fog lamps that did not come with my 04' crew cab. Any help would be appreciated such as what wires go to what, its pretty much plug n play with the connector pieces, theres a few wires im not sure where i should be running.
Back to Top View Drews04fronty's Profile Search for other posts by Drews04fronty
davidjbrady
Posted: Jul 09 2010 at 10:14am | IP Logged Quote davidjbrady
Nothing came with the lights in terms of instructions?
08 Frontier CC, 4X4, LWB
Drews04fronty
Posted: Jul 09 2010 at 10:57am | IP Logged Quote Drews04fronty
No there were no instructions. all the necessary parts i have just no diagrams or instructions. and guys at nissan are useless
Posted: Jul 09 2010 at 7:16pm | IP Logged Quote frontierguy
The connectors for the lites should be taped to the harness near the opening for the fog lites. The fog lite switch is part of the head lite switch, correct?? Just remove the existing one and install the new one.
m8kitrun
U.S. - Tennessee
Posted: Jul 10 2010 at 1:08am | IP Logged Quote m8kitrun
i am very new to this so you may very well discard my input, but are you wanting your fog lights to be completely "factory"?  i just installed fog lamps on my '10 frontier using only the factory lamps themselves and wired them myself so i can turn them on at will and don't have them shut off when i turn on the brights. everything looks "factory" but i have more function. if you are wanting completely "factory" fog lamps then i cant offer much help, but if you are looking for advice to get them working then let me know and i can give you a very easy solution readily available at your local parts store with instructions and all.
Back to Top View m8kitrun's Profile Search for other posts by m8kitrun
Drews04fronty
Posted: Jul 10 2010 at 4:51pm | IP Logged Quote Drews04fronty
KEEP in mind this is for an 04' Frontier
They are factory lights, with a wiring harness, NO SWITCH ON STEERING COLUMN
It is a switch that mounts next to teh steering wheel so i can turn them on when i want.
i just dont have instructions on where to run wires
Posted: Jul 11 2010 at 8:02am | IP Logged Quote frontierguy
When you say FACTORY, did you purchase them from a Nissan dealer???? A lot of aftermarket use the wording "factory".
The FACTORY fog lite switch is on the headlite/turn signal switch.
Drews04fronty
Posted: Jul 11 2010 at 9:51am | IP Logged Quote Drews04fronty
it is aftermarket, but its exactly the same as factory, same harness and all
Posted: Jul 11 2010 at 7:38pm | IP Logged Quote frontierguy
If it is aftermarket it is not the same as factory. The fog lite switch is on the same stalk as the headlite switch.
Drews04fronty
Posted: Jul 12 2010 at 6:28pm | IP Logged Quote Drews04fronty
OK so here is a few pictures of what im talking about from the Light all the way to the Switch inside the car. hopefully someone can shed some light on the situation and help me out thanks guys!
Page of 2 Next >>
