| Posted: Apr 01 2012 at 6:03pm | IP Logged
The supercharger kits are expensive, and the tune will be
interesting as the kits are designed for the 240sx. JWT
can help with that.
The easier and cheaper route would be to go with a turbo.
Be it a conventional on the manifold or a Squire Turbo.
However the whine from a roots blower sounds way cooler.
That's the route I'll be going with my X-Runner.
Best piece of advice I can give, research and talk all
the companies you can. Make sure before you buy anything
you've tracked down and priced EVERYTHING you're going to
need. Here's a good place to start.
KA24DER.com
