| Posted: Aug 20 2006 at 9:00pm | IP Logged
I had a roll top cover on mine. Worked really nice, but required a bit of maintenance. Soft tops require you to flip the strips between summer and winter since the top shrinks and expands with the cold and heat.
This single piece fiberglass doesn't require this, and can be painted, but you don't have much height. The roll top is nice since it rolls into a compartment, but takes up a small section of space in the bed.
